kfp673's avatar
kfp673
Explorer II
Jun 01, 2021
Axle upgrade questions
Hello All,
We have a 37' outback travel trailer that I recently installed CRE3000 MorRyde equalizers. When I had the wheels off I noticed some uneven tire wear. The inside of the tires has worn much more than the rest, and getting pretty smooth on the inside edge. From what I have read that is typically caused by alignment issues or overloading. We have about 10k miles on the trailer and these were the stock tires so I am going to replace them with Goodyear endurance, but my question is, does it make sense to also upgrade the axles? I do not have a recent scale weight and I know that is going to be some of the replies, but I believe it may be due to how often we run with a full tank of water. We are often off grid and need to cary the full 55 gallons. Beyond that we pack food and the standard RV items. Again, I know getting an accurate weight is the correct thing to do, but I guess my point is, the way we pack I do not think is extreme and we will likely continue to pack the same way. That said, will upgrading the axels help this situation? Should I continue my search for a shop that can align trailer axels? (Called 2 trailer shops so far and neither of them do this. Not sure about the RV dealer). And, if I upgrade the axels to one step heavier, do I also need to replace the leaf springs?
Thanks!
