Stclairm
Oct 15, 2020Explorer
Azdel or not?
I keep seeing so many stories about fiberglass walls delaminating and the such with luan as part of the construction. I see people who don't even have water damage and the walls are coming apart. So...
goducks10 wrote:
Since Azdel is a man made product and the exterior fiberglass is as well even if you get water in between and you get some delam you shouldn't have the big pucker bubbles like you would with luan. Luan will breakdown and pucker and separate like plywood will. Think of Azdel like you would cement board siding for houses. It's virtually impervious to water.
I think it's better than Luan but in the end I want a floor plan I can enjoy. So many other factors come into play when deciding on an RV.
Siding is one as is the frame, suspension, lighting, interior finishes, storage, layout, etc.
If you take care of your RV with regular maintenance you should avoid most problems. I've seen 10-15 year old RV's with fiberglass over laun walls that look fine. I've seen new ones that have had delam within a couple years. Those latter are rare IMO. Get a plumbing leak and there goes you floor regardless of what walls you have. Maintenance, maintenance maintenance.
