- Boon_DockerExplorer IIIIf you have a single (one) positive cable coming from the batteries to the trailer cut the positive cable and install one of these.
- SoundGuyExplorer
tshirtman wrote:
OK, OP HERE---
SOMEONE PLEASE JUST TELL ME IF I HAVE 2 BATTERIES FOR THE TRAILER AND WANT TO PUT ON A DISCONNECT SO THE PHANTOM DRAW STOPS DRAWING,
HOW TO DO SO. IS THERE A SPECIAL DISCONNECT FOR A DUAL(TRAILER)BATTERY
SYSTEM.
I already provided you with that answer back on Page 1 of this discussion. ;) - tshirtmanExplorerOK, OP HERE---
SYSTEM.
THANKS TO ALL - wrenchbenderExplorerI use a Marinco rotary Switch
- MKirklandExplorerI wasn't confident in my ability to do the wiring. I had a professional do it and I have been very happy with his work. Especially, it is nice to turn off the batteries during anytime we aren't using the trailer. The switch was placed inside in a location that looks perfect for it.
- SoundGuyExplorer
westend wrote:
Terminate the disconnect switch onto the (+) phase wire that enters the trailer. Be sure you still have some manner of circuit protection like a fuse or circuit breaker inline.rats1955 wrote:
What amp circuit breaker should you use?
Your trailer should already have a resettable circuit breaker wired in line from the battery's positive terminal ... 30 amp is a typical rating. - rats1955Explorer
What amp circuit breaker should you use? - westendExplorer
tshirtman wrote:
You're welcome. If you have any more questions, just post them up.
Thanks Westend---
your reply was the most helpful:) - Gene_GinnyExplorerThat is the back side of the "Blue Sea m-Series Mini Model #6007" I posted earlier. It is a double pole switch. The 6006 is a single pole switch.
Here is the URL to the picture:
http://i.ebayimg.com/images/g/GTwAAOSwQYZWvP2i/s-l400.jpg - tshirtmanExplorerCan not see pic
Please send make and model and ill look it up on line
thx
