Lowsuv wrote:
just the facts ...
line by line explain to me
O.K...
I'll take this one:
Lowsuv wrote:
6. 99 % of LT tires are rated to 99 mph ( exception is G rated tires , etc. ) 99 % of ST tires are rated to 65 mph .
even if you are only going 64.999 mph a 99 mph rated tire has additional reserve capacity .
-In the first place, LT tires are excluded from all labeling requirements attached to P tires, including that for speed rating. That designation is purely voluntary on the part of LT tire manufacturers.
-The "speed rating" attached to LT's is 75 mph, and the vast majority adhere to that minimum, some mud/snow tires representing the majority of the exceptions. That's the standard used for testing for compliance. It was developed through cooperative effort between the industry and the NHTSB, and is reflected in the table given at
Michelin's speed ratings page.
-That said:
Even those few LT's with higher speed ratings on the sidewall are NOT typically approved by their makers for the stated speeds when used on an RV of any kind, including trailers. One notable example of such derating is the well-known Michelin Rib- Q" rated (99 mph) if used on
light trucks, but downrated to (the minimum) 75 mph if used on an
RV/trailer.
