- gmcsmokeExplorer$500 to tell me all the readings are at or below stock limits? no thanks.
- powderman426Explorer
APT wrote:
You may want to monitor boost and/or EGT. If you have an Android based smartphone, I highly recommend the Torque Pro App ($4.99 on Google Play) plus one of a number of Bluetooth OBDII adapters for under $20 shipped on Amazon.
Yep. This combination works well, is super cheap, and doesn't require any changes that would cause problems at the dealers. - APTExplorerYou may want to monitor boost and/or EGT. If you have an Android based smartphone, I highly recommend the Torque Pro App ($4.99 on Google Play) plus one of a number of Bluetooth OBDII adapters for under $20 shipped on Amazon.
- Me_AgainExplorer IIIExtra gauges are not as important on the new trucks. Their computers protect the engine and tranny pretty well. Also there is a fair amount of info available via the dash display if you poke around. Adding anything the raises a flag to the dealer regarding warranty is not a good idea!
Just us it and enjoy it.
Chris - davisenvyExplorerHow heavy is your 5th wheel? I like the Edge Insight CTS. I had to tap into the exhaust manifold for the exhaust gas temp probe. There are 22 different sensors to monitor and you can also use the Insight as a back up camera. Saved my marriage ;)
44,056 PostsLatest Activity: May 04, 2014
