OLWalker
Jun 25, 2013Explorer
Buck50HD wrote:
Theoretical stopping distance (you can verify this with just your unloaded vehicle) should be less than 30 feet from 25MPH. This does not include reaction time and assumes pavement and decent ABS performance. It also assumes your TV has enough brakes to lock all 4 on pavement (I know the Tundra does).
At 113 feet, that is worse than expected with no trailer brakes at all, especially with a Tundra and that small trailer. Are you sure you are getting the truck to cycle on ABS? You're not going to hurt it if you just do one panic stop and let it cool.
If you have 10" brakes on that light of a trailer, it should lock unless there is something wrong or just have not worn in yet.
Buck50HD - just want to make sure I understand.
1. I am stopping at 113 feet just using the manual override on the brake controller and the trailer brakes. I am not pressing the brake pedal on the Tundra pickup. The Tundra has some pretty awesome/oversized brakes, so I'm pretty sure I could stop it pretty quick using the Tundra brakes.
2. I've driven about 1,700 miles with the trailer (and I'm pretty sure they are 10" brakes). Do you think the brakes might not have burnished in at 100% yet?
Sounds like the consensus is that I should be able to lock up the brakes on the trailer.
44,068 PostsLatest Activity: Jun 21, 2026
