brholt
Mar 21, 2016Explorer II
fpoole wrote:
Arctic Fox 990 is fine, but the only caveate is not to fill the water tank up if OFF the truck with out support. Apparently the bladder will buckle the bottom or something like that.
I've had it off a few times, lowered to a few inches off the ground, works/feels fine...
It does get a little 'iffy' when I have to load in the wind, as in "Yikes, what was I thinking...." so it's a quick load if windy if I have too...
Hope that helps...
No, you can fill your Arctic Fox off the truck too. What you can't do, on or off the truck, is fill it with a high pressure source of water. The vent/overflow tube is pretty small and if you pressurize the water tank it will bulge possibly breaking things. (Pressurizing the fresh water tank will cause problems for any camper but other brands may have bigger vent/overflow lines).
44,066 PostsLatest Activity: Jul 25, 2018
