MFL
Dec 23, 2020Nomad II
I think in many cases, the carpet is there to aid in sliding. The part that touches/slides on carpet, should be smooth. I too can see lines in carpet, with slide extended, but not worn through...yet. I think on mine, it would take a long time to actually wear through the carpet. If an adjustment will lift from the carpet a bit, it may cause issue with some other point of contact??
I've read of different fixes, on these forums, but hard to find when searching. IIRC, most put a protective piece on top of the carpet, but you would not want something that would catch, when extending/retracting.
Jerry
Jerry
