JBarca
Dec 30, 2020Nomad II
MeloyeloCJ7 wrote:
Yes sir that is the exact floor plan of our TT. From what I know, it’s a Lippert brand slide unit. As far as mileage I have no idea. :) It is also flush floor type setup. Thanks for your reply.
OK, this is a start. Good. You have the flush floor setup, OK that helps as there are more things to look for on them. If you want to take this further to look at the mechanical areas of the slide which can cause carpet drag, we need more info so we do not tell you the wrong what to fix.
We need pictures of your camper in these areas "as a start" to see and explain what you have, and where to go looking next. More pics may be needed later pending the first go around.
1.The slide side of your camper, showing back of camper rear wall up to and past the front axle and the front of the slide.
2. The slide drive system under the slide room. Need the see how the slide arms attach to the slide room outer wall. Both front and rear slide arms.
3. Pic's of how both the front and back slide arms go through the trailer frame. Need to know which pic goes with front and which with back of slide.
4. If your slide drive gearing, square shaft and slide motor are "not" under a camper bottom cover, take pics of the gearing, and motor drive system.
Since Lippert (LCI) bought a lot of slide drive companies in the last few years, it is hard to tell which Lippert slide drive you have. The various brands have different setups and wear points. What we tell you can be wrong for example, if you have a Power Gear slide drive OR you have the older Lippert rack and pinion drive that LCI actually made years ago. The adjustments and wear points are different.
I am going out on a limb here as hopefully FR used the heavy LCI rack and pinion drive on your big slide. These pics are of the Lippert original rack and pinion system on a flush floor setup. Does your looks like these?
Inside the camper when the slide is in, there is a large gap under the slide floor to the carpet in the center of the camper. Does your have this?
Under the slide room, there are slide arms, a master rack side arm (has the motor drive on it) and an auxiliary slide arm (driven from the square shaft)
Master rack arm. These are different trailer brands but the same LCI slide drive, but the drive can be configured a little different in left, right, inside frame or outside frame mounts.
On a Skyline camper
On a Sunline camper
The motor drive on the master rack arm on a Sunline. This is under the bottom cover on this camper.
Auxiliary slide arm, driven by a square shaft.
On a Sunline camper
On an Artic Fox camper
Lets confirm what you have, hope to see pics and then I can help tell you where to start looking.
There are many areas on a flush floor setup that can cause carpet drag on an older camper that never drug when it was newer. If yours did not drag when new, approx 0 - 4 maybe 5ish years and now does, then we need to check all the "normal" areas that can flex, wear or fall out of adjustment "before" we adjust the slide room. The symptoms of a carpet drag can be a early detection of a larger problem, or not. Knowing where to look, only takes a little time if you have been through this before, but trying to explain it and get it communicated, can take longer.
I'm willing to help explain it all as needed, if you can do the looking, measuring, pic taking and want to deal with doing all this learning.
Hope this helps
John
