DoneItAll's avatar
DoneItAll
Clearance Lights - Replacement
I have found it necessary to replace a couple of bulbs in my 2008 Lance clearance lights. Are the lens held on with screws or simply held there by the sealant? If so, do I just pry them off to gain access to the bulb? To reinstall, remove all the sealant and reseal?
Thanks,
John
  • why bother, unless your state has inspections and requires them.
    bumpy
  • Should be an amber lens on a white plastic base,right? The lens should be a friction fit, the base will be screwed + caulked / butyled
    I replaced all the clearance lights on my 2007 TC with LEDs earlier this year. After that many years a lot of them were worn/cloudy/cracked. The LED ones look a lot nicer.
