FishOnOne
Oct 05, 2013Nomad
Cummins ISV5.0
Looks like the Cummins 5.0 uses a Bosch CP4.2 HPFP, Intake ports that look very similar to a 6.0 psd and uses 4 bolts/cylinder. In addition no more gears to turn the HPFP and the cams.
Video
Video
womps wrote:
It might, but the Ram 1500 would not have enough payload to carry it!!!
thomasmnile wrote:Me Again wrote:45Ricochet wrote:
Yeah I saw that also and believe your right, a CP.4 for 2016 requirements. No wonder Ram went with the Fiat-GM diesel in their 1500's :B
Boy I hope Bosch got that little dollar item fixed by now :W
On edit HERE is another link without the annoying sounds Troy.
Hopefully they will have as much luck as they have in the I6 market.
Interesting that they said first V configuration Cummins. Did they forget about the Triple Nickel Cummins (VT-555)?
http://www.youtube.com/watch?v=WqnK80hCQbg
Chris
Or the Cummins 903 for that matter.......Oops, don't think a 903 would fit under the hood of a Ram 1500........:B
Chris
ScottG wrote:hmknightnc wrote:
I sure wish Ram would offer one of those in the 3/4 ton model. It's all the engine you need for 3/4 use and we would be back to decent fuel mileage like the older diesels used to do.
You know, thats an interesting point. If they put it in the 1500 quad cab then that's exactly what you'll get because as I understand it, that model is actually a 2500 with all the same HD hardware.
