Christl
Jul 31, 2014Explorer
Dicor or Eternabond Tape -Which is Better
Hi Folks: Looking for recommendation on which is better to use on covering the seam along the top flat edge of an aluminum roof - eternabond tape or re-caulking with Dicor? The white aluminum roof has a orange peel surface to it. It looks like the original sealing compound is Dicor. I have cleaned the surface of the Dicor caulking and aluminum roof well and could apply a 2 inch strip of Eternabond tape covering the seam and the old Dicor so that the edge of the tape was also on new clean aluminum roof. The alternative is to re-caulk with Dicor? Does anyone have experience with which will provide the better longer lasting seal? thank you for your input. I have used Geocel ProFlexRV and got good results on vertical seams and around lights etc. but have not use Eternabond tape or Dicor yet.
Here are some pictures of the cleaned section of the roof edge.
