RZAR66 wrote:
You're throwing away some serious money changing your oil so often. You're good for at least 10k with that engine.
Says who?
The 6.0 and 6.4 are extremely temperamental about oil/filter and fuel. Mainly due the close tolerances of the HEUI injectors. Not to mention the HPOP shears the oil almost immediately. Combine those two things with the high heat generated, stretching the intervals out too far, you'll be on the side of the road sooner than later.
The recommended OCI for both engines is 5K. If you have a by-pass filter, maybe 7.5K...MAYBE. It's highly debatable. He's doing it right. 10K, and you're looking at prematurely killing the injectors, the turbo bearings, the HPOP. Oil, fuel and filters NEED to be changed on schedule with these engines. Then there's the coolant side of things, but that's a whole other topic.
