- RandACampinExplorer IIprobably wont do your bumper any good.
- Dave_H_MExplorer IIFord guy. In reading between the lines there seems to be plenty time to make some decisions. This is what i did and would advise.
Pull into a ford dealership and pick up a brochure on the F250 that has all the specs and options in it. Just about all of what you need/want will be standard. Also if you have any questions like bed height etc, take a measuring stick with you.
In about 8 weeks you can have the exact truck you want including color et all.
So in 2012 I ordered a crew cab short box F250 XLT and added on sprayed in bed liner, side moldings, upfitter switches, and 4.30 differential.
Since i don't need it, I also got 2 wheel drive.
Also take note of the tow rating of the standard diffy as opposed to the 4.30.
Now if you are lucky like I am, the stelership has the best pop corn in town also. :W - Grit_dogNavigator
georgialawn88 wrote:
I just meant extra strain. Like I'm not gonna blow up the motor pulling that. This will be a new 2018 f250 when purchased
Good gosh, no. It will be totally fine, even with 3.73s.
Agree on getting the deeper ratios though if primarily towing or in the mountains or altitude.
Have had a couple of the older 6.2 F250s. Both with 3.73s and pulling a grade even at low altitude with considerably less than a 10klb travel trailer resulted in more 2nd gear pulls than I would have liked. Pretty sure the deeper gears will keep it in 4th and 3rd longer. - ib516Explorer IIDon't be afraid to let the engine rev when needed (5000 RPM+) the computer won't let it rev high enough to damage it and that range is where gas V8 engines make their power.
- blt2skiModeratorDriving your truck empty puts a strain on the system..........Yes heavier loads puts more strain on the system........A truck is a tool, designed to do certain things. I run down the road with a motor that has less HP, torque etc, at 26000 lbs than your new to you 6.2 V8 Gas puts out. Its a diesel granted. but I would still run down the road with the 6.2 gas V8 in the truck at 26000 with out thinking twice. Thats GVW, not GCW! upwards of 30-35K gcw! You're not even working that motor!
Marty - ppineExplorer III think 10,000 pounds puts a lot of strain on a truck. Drivetrain, brakes, steering and suspension. The way you drive also contributes to the amount of wear and the longevity of the engine and transmission.
You will like that experience.. My BRO In Law pulls his 11K TT with his "15" f-250 with 6.2 and loves it...- LanceRKeysExplorerI would suggest you find one with a 4.10 or 4:30 rear end if available. When you find one you like post the specifics about it here, don’t believe your salesman.
- MFLNomad IIThe manufacturer gives a GCVWR to answer the question you are asking. This number on a newer gas 250 will be around 20K, depending what gear ratio the truck has. So if your new 250 weighs 7k, you would be able to tow 13K, without harming the drive train.
Jerry
44,027 PostsLatest Activity: Mar 12, 2025
