hitman98's avatar
hitman98
door lock
So I went to my trailer today and put the front door key in the rear key lock but for the dead bolt. Then what's occurred is I cannot put the right key into the dead bolt key hole but it will fit into and operate the top keyhole? I've tried wd40 and still I cant get the key back into the keyhole. I went inside and unscrewed the whole lock assembly but the deadbolt is engaged? need help! 2004 28ft keystone zeppelin
  • You probably have a known defective lock. There is a recall for the defective locks. As I recall the problem arises if you remove the key from the lock when it is in the 3 o'clock position. You must always return the key to the 12 o'clock position. There is a website where you can apply for a free replacement. Search this forum to find lots of posts on the issue.
  • Hubby just replaced our lock assembly he got locked out and had to drill lock out to get in. Plus side door has never closed so good!!
  • You're going to need a whole new lock assembly - top, bottom, handle, and all.
