billyray50's avatar
billyray50
Driver side door and window whistleing Dixie??
The driver side door on my 2006 Dodge 2500 CTD 4x4 is not sealing properly. The noise level from driving even at low speeds has become deafening. I owned truck since buying it off the lot and noticed it has been getting worse in the last year. Passenger side is air tight. I know in the past 8 years the driver side door has been blown open 2 times in strong wind gusts that almost ripped my arm off. I check all seals and compared them to passenger side and all looks good but when I shut it door does not sound the same as passenger side. I tried to tighten down door brackets too already. I did notice some brackets hinges do not look flush compared to passenger front door. Took some pics. Could this be the issue? The first 2 pics are the front passenger door and the second 2 pics are the drivers side door. Can I put some shims in brackets and if so what kind?
