- parker_roweExplorer
paulbeauchemin wrote:
I see - if replacing just one of the tires in a dually that this would be critical
But if you replace all 4 is aspect ratio critical?
As long as it isn't 4wd, no. Front and rear tires need to be the same diameter in 4wd, or the transfer case won't be happy. - Grit_dogTrailblazer
parker.rowe wrote:
Aspect ratio? As in the "75" in that tire size?
That is pretty important. It IS the tire height.
245=tread width in mm
75=sidewall height as a % of tread width. ex: 245 x 0.75=183.75mm
17=rim diameter in inches
So...
total sidewall height in mm = 183.75*2=367.5
total sidewall height in inches = 367.5/25.4=14.47 inches
total diameter = 14.47+17 = 31.47 inches
Of course, there are discrepancies from tire to tire and manufacturer to manufacturer. But that is what the numbers are suppose to mean.
No, it's not. Neither is diameter within reason. Small change in dia will be indiscernable. Even a couple inches in dia will not make much difference.
I'd run 255-80-17s. A little extra meat on the rims would be nice compared to 245s. - paulbeaucheminExplorer
So...
But if you replace all 4 is aspect ratio critical? - parker_roweExplorerAspect ratio? As in the "75" in that tire size?
So...
Of course, there are discrepancies from tire to tire and manufacturer to manufacturer. But that is what the numbers are suppose to mean. - BenKExplorerSuggest using "rev's per mile" over just dia...have found there is difference between exact same dia's, but different OEMs and even within the same OEM, but different models
- donn0128Explorer IIYou have to be careful to maintain the distance between tires. Too clode and they could rub under load causing a failure. So yes aspect ratio is important on a dually
