dcb17b
Jun 19, 2014Explorer II
Most trailers have the same "guts" regardless of it's position on the mfgs line up. The biggest difference is base units may not have an oven,3 way fridge,DSI ignition on fridge/water heater and things like that. Fabric,trim choices,window coverings,entertainment devices are a lot of the items that are upgraded on higher end units. It is not true that a more expensive will last longer or is built better. Look for a unit that suits your needs and is within your means. How you use the camper will define some of the things that will be important for you to have and some of things that won't be worth paying for. Best of luck in your search and keep us posted. Glad to answer any/all questions you have.
44,071 PostsLatest Activity: Aug 30, 2026
