4x4ord wrote:
^^^ Are you thinking that F450 buyers don't register their trucks to haul above 14k lbs? Who's buying these trucks and what for? I'm sure if comercial buyers are hauling above 14k they're registering their trucks to haul above 14k. Come to think of it I actually only know of one F450 pickup owner. I've got a nephew that bought one to haul his ego around with. Is the F450 an F350 with the wide track front axle? Is it anymore capable than the F350?
Are you under the mistaken belief that the F450 pickup is just a 450 cab and chassis with a pickup bed? It isn’t. Between the back of the cab and the rear bumper, the frames are completely different. Commercial buyers aren’t going to buy the F450 pickups.
Who’s buying them? I’ve bought two. First a 2010, and now the 2016 in my sig, and you can see what I’m doing with it. The 2010 actually had a 14.5K gvwr, making it a “just barely” class 4 truck. But, I think that ultimately caused some problems for some buyers with licensing, registration, and insurance. I believe it also could have created a situation for Ford where the F450 pickup was reducing sales of the 450 cab and chassis. Corporations usually try to avoid having one product line compete with another.
Comparing the F450 pickup to the F350 pickup, at least in the 2008-2010, and the 2014-2016 model years, they were undeniably more capable. The 2011 through about 2013 F450 pickups were (IIRC) just rebadged F350’s, and I’m not quite as familiar with the current model years. But, even if you include the F350’s that had the wide track front axle (which isn’t available for the F350 any longer) the F450 pickup axles were rated higher by the axle manufacturer. The brakes were also bigger, and the trucks came with 19.5” tires. Those were all desirable to me.
My camper and gear weigh enough that either truck would have been at max gvwr when loaded, so why not go with the one that has the heavier rated tires, wheels, brakes, axles, and a tighter turning radius?
