wilco83's avatar
wilco83
Fixing tongue weight
After years of tenting I just bought a '78 Travelaire so that we can take our one-year old on camping trips this year. When I hitched on, I noticed the back of my vehicle was sagging quite a bit, so I took everything to a public scale to figure out my tongue weight.
The trailer weighs 2,600 lbs, and is no issue to pull for our vehicle (Acura MDX), which has a towing capacity of 5,000 lbs. My tongue weight cannot exceed 500lbs.
Acura does not recommend using a weight distribution system. I do use sway bars.
The challenge I have with the trailer is that the tongue weight is way out of whack. The scale wasn't big enough to fit both the car and trailer at the same time, but I think I got all the weights that I need.
The GVW (trailer hitched, me in it) was 5,357 lbs.
The vehicle (trailer unhitched, me in it) was 4,564 lbs.
I believe this means that the tongue weight is the difference between the two, or 794 lbs.
The trailer was loaded with our regular campaign gear (chairs, pots, pans, etc) but did not have water in it yet. Most of the gear was in the back of the trailer.
When I go ahead and sit in the back of the trailer, the GVW reduced to 5,115lbs, reducing the tongue weight to 551 lbs.
The only other thing I can think of doing is removing the two propane bottles on the front of my trailer when traveling, and placing them inside the trailer. But, it seems odd to me that I'd have to do that every single time.
So, a few questions:
- Does my tongue weight logic make sense?
- Other than moving the propane bottles, and always driving with full water tanks - how can I try to reduce my tongue weight?
- How the heck can a trailer's tongue weight be so out of whack?
Any ideas on how to resolve this would be greatly appreciated!
  • @ScottG - I've filled the trailer with water and will give it another go tonight. There's also another scale on the way back from our camping trip this weekend so I will take your advice and visit that scale as well. Acura claims it will hinder performance/breaking/etc but it is indeed a unibody.
    @BurbMan - I weighed the trailer when attached to the vehicle and it was 2,866 lbs, add back the tongue weight, and it's 3,660 lbs (again, this is with most of the stuff we bring camping). I agree that it all seems to be a bit heavy although the maximum trailer weight (4,400lbs) does fall within the guidelines set by Acura. I now have the trailer loaded with water too, so I think it would be a good idea to take it back to the scale again and see what that does.
    @Olde Volks - My wife and kid and some food will be a couple hundred pounds. As long as I can get that tongue weight back where it should be, that shouldn't be a problem I think. I
  • my 1st ? is what are the weights going to be when the entire family is in the tow vehicle, with all the items that have to come along for entertainment,snacks,cooler,comfort etc.
    and 2nd would the TT become more unstable with more weight placed behind the TT/s wheels.
    and just a thought, will it be safe to travel down the road with 2 FULL propane tanks not properly secured to the TT frame,then add NO anti sway control.
    I know I feel unsafe just coming back from getting them filled and them being unsecured in my vehicle (I trust my driving skills) it's others I don't trust and anything can happen at any time
  • I would go back to the scale and verify that the trailer is indeed 2600 lbs....that may be why your tongue weight seems out of whack. Just weigh the trailer axles, then add in the tongue weight to get the total trailer weight.
    Be careful about unloading too much weight from the tongue....not enough tongue weight will cause the trailer to sway badly over 40 mph.
    I would be looking for a popup to tow behind a vehicle like the MDX.
  • Your logic sounds right to me.
    You could maybe offset the tongue weight by filling or emptying the water tank depending on where it's located. Other than that you'll need to move as much weight as possible to the back of the trailer.
    Acura probably doesn't like WDH because it's a unibody (just a guess) and can actually damage it.
    You might also try another scale. I've found that even "certified" scales are way off the mark sometimes (one said my truck weighed 8500 and another said it was 9900 - both empty. Highway weigh stations all say 7200).
    The scale probably has poor accuracy at that low of weight anyway.
