spoon059 wrote:
Ford made a LOT of the 6.0 and 6.4 Superduty trucks. I would venture a guess that 90%+ had no major problems and there are plenty of people that don't frequent internet forums and have no idea that anything could be wrong with the truck.
The problem is that the relatively few trucks that have problems tend to have a MAJOR problem. My friend has a 6.0 in his F250. It was a great truck... until he had problems with the top end of is engine. He had to spend a good amount of money fixing it... but hopefully it will last a good while longer.
Chances are that you could buy that 6.0 and have many trouble free years and miles. The only problem is that you might be one of the unfortunate few that gets saddled with a major repair expense. For some people its worth the risk, for others it is not.
Many sources say the production of the 6.0 engine was around a million units.
Ford, in court said this engine cost them over a Billion dollars back in the day in warrantee work. (Years later it's well over that cost now.)(Many were over warrantee period when they blew up so Ford never fixed those on their dime or the customer took them to private mechanics to save some $$$ so the figures are much higher.)
Simple math tells us that every single 6.0 built needed $1,000 in repair...........or 1 out of 10 cost $10,000 to repair...........or every other 6.0 built cost 5 grand to fix.
Since a headgasket job back in the day cost around 4 grand at the dealership it's highly unlikely that 1 out of 10 trucks were fixed for 10 grand.
It's also highly unlikely that every single 6.0 made needed $1,000 in warrantee repair.
Logically, the truth is going to be somewhere around the middle. If so, that means every other 6.0 engine made needed $5,000 dollars in warrantee repair work; or a half a million 6.0 engines needed repair work done to them. :E This is a far cry from the "90%+ had no major problems" that you state.
Even if we use your figures of only 1 out of 10 trucks needed repaired that 1 truck needed $10,000 in repair work in it's warrantee lifetime. :E Like I said, that means one could do 2 headgasket jobs and $2,000 dollars of other repair work on this one truck. :E
