BigToe wrote:
Just for the record, many Ford pick up truck frames have a moon shaped cut out in the lower flange to provide clearance for the shock absorber.
Frame cracks on Fords equipped with air bags typically initiate from this lower flange cut out area, which is very near where the air bag mounting apparatus is bolted.  The crack propagates upward, until arrested by an existing hole in the web of the frame.   Very common.
The most important two parts of a C channel truck frame are the upper and lower horizontally oriented flanges.  The vertical web of the frame's main purpose is to keep these two highly loaded flanges at a prescribed distance from each other.  Ford permits drilling into the vertical web, but forbids drilling or modifying the all important horizontal flanges.  The upper and lower flanges are subjected to the greatest proportions of compression and tension.
So it is not surprising that an already scalloped lower flange cracked when subjected to a concentrated load placement (from the aftermarket airbag) in an area of the frame that was not designed to bear that load.  The frame is designed to take the load at the spring hangars, not at a mid point between the spring hangars.
All the air suspensions on big semi trucks and trailers are completely irrelevant to this discussion.  The issue isn't air or bags.  The issue is placement of stress on a specific area of the frame that was not only not engineered for it, but is in fact actually weaker in that specific area due to the half moon shape scallop out of the lower flange for the shock clearance.
For this reason, if more rear spring capacity is needed, then a heavier overload spring might be a better way to go on certain Ford pick up frames.
This is exactly correct.
I have welded up the frame of an F550 that cracked on both sides, both starting in the middle of that scallop in the lower frame rail.  I end drilled the cracks to keep them from running, beveled them out and welded them up.  Then I cut out 2 half circles of 1/4" plate, which I used to fill in both of those scallops.  Next, I fish plated the frame on the outside webs.  Finally, I cut off both upper shock mounts and spaced them inboard about an inch, to allow clearance for the shocks with the frame scallop filled in.
All Ford had to do to eliminate this common Superduty frame cracking  problem was move the upper shock mounts inboard about an inch, like I did.  That would have allowed the frame to have a full width lower flange, with no cutout for shock clearance.  The shocks would clear and operate fine and the frame strength would be increased many times.
Amazing what these engineers come up with for solutions to problems that don't exist, thus creating problems that weren't there to begin with...
