austinjenna
Jul 20, 2017Explorer
Ford shift on the fly - no 4HI
2010 F-360 6,4L
My electronic shift on the fly will not engage in 4 HI. It will go into 4 low, comes back out into 2HI just fine, just no 4HI. I can manually lock the hubs and it will work, just not from the dash switch. The light on the dash does come on as well if I use the shift on the fly.
Since I can manually lock in the hubs and it works I have eliminated the hubs. I tried the defrost/vent trick and it works as it should. I know these things work on vacuum and since its going into 4low I can eliminate a vacuum leak. Im just trying to debug it before going to the dealer.
Any ideas on where to look?
