Colo_Native
Jan 03, 2017Explorer
Fumoto Valve
How many are using a Fumoto or similar? I getting tried of cleaning up after oil changes, what are the issues? I know they don't drain as fast possibly leaving sediment in the pan. Thanks
Cummins12V98 wrote:Exactly, trying to get a sample from the gush of oil when the drain plug is pulled makes one heck of a mess. I open the Fumoto valve, let it run for a couple seconds, and can easily catch a sample mid stream with no muss, no fuss. That actually was the main reason I thought about the Fumoto valve in the first place. I send a sample off to Blackstone Labs at every oil change.fj12ryder wrote:
I'll chime in on this one too. I have them in all my vehicles, except the bikes. They are perfect for pulling oil samples for Blackstone Labs. I always made a mess with the truck because the oil just gushed out and I always dropped the plug in the hot oil.
Up to you but samples are supposed to be taken mid stream as the first oil has more contaminants.
I don't trust people, very easy to let all the oil out. I use a milk pail to drain oil with zero splash or spills.
otrfun wrote:Yeah, I kind of thought that myself since I have a Fumoto valve on my Cummins. But the possibility of something smashing the valve off seemed to be remote enough to not be a worry. I tried using the bucket but still ended up dropping the drain plug in the bucket and had to fish it out. Once was all it took. :) Of course if I was doing any offroad excursions it would be a different story, but all my driving is on pavement.ktmrfs wrote:I guess I'll be the lone dissenter here. I really wanted to use one on our Cummins. All that splash from my first oil change was plenty of incentive to use one. But, I just couldn't bring myself to use one after seeing how open and vulnerable that oil pan area looked to me on our Cummins. I'm sure the odds of road debri dislodging a Fumoto are low. However, I've personally experienced how fast things go south when there's no oil in the engine---just seconds. Anywhoser, once I discovered a 3.5 gallon paint bucket works flawlessly for oil changes, I never gave the Fumoto another thought.
. . . The only thing to consider is if the drain plug goes straight down and is unprotected then don't use the fumoto valve with the nipple on it. Otherwise use the fumoto valve with the longer nipple and slip a piece of tubing on it when you drain.
