ADK_Camper's avatar
ADK_Camper
Fun Finder is letting me down
I have a 2012 Fun Finder. To be fair it has been very trouble free since I bought it in 2011. But I have had two problems surface in two days. They may not be all that serious, but I just don't think we owners should excuse manufactures' carelessness and choice of inferior quality components.
The first problem is a failure of one of the ball valves on the water heater bypass. I went to change their positions when preparing to use the water heater for the first time this season when one of the valve stems broke. It's now permamently in the wrong position to obtain hot water from the tank. Now these valves only change position twice per year. I calculated that they have been "turned" exactly eight times since the trailer was new. I don't care how cheap a component is; it should last longer than eight cycles
The second problem is the failure of one of the LED marker lights. These LED lights are supposed to be rugged and last for thousands and thousands of hours. They probably would, but some careless worker actually installed one of mine upside down; it filled with water and no longer works. When I removed the cover on the bottom it was clearly stamped "TOP" A weep hole that should have been on the bottom was on the top. It admitted water which had no way to exit.
  • You're right, that Fun Finder is about to fall completely apart. Tell you what, if you'll meet me halfway I will relieve you of that miserable trailer for, say, $3000. Sound good? :B
  • PackerBacker wrote:
    Just curious, I wondering why there is more than one bypass valve for the hw tank. I've owned many rv's and have never seen that before.
    Mine have always had 3 valves...
    Exactly like this:
  • Those plastic CPVC valves are notorious for poor quality. They are barely better than a plastic irrigation valve (in fact, probably less durable).
    The LED marker fixture may have a universal lens attachment. Try flipping the lens and see if it clips on correctly.
    Count your blessings if these are the only two repair items you've had in four years. Many have it a lot worse.
  • Community Alumni's avatar
    Community Alumni
  • You are way, way ahead of the, "RV game". Two minor issues since 2012 on a 2011 entry level model....
    Go out and buy a lottery ticket...you are on a winning streak.
  • Is the glass half full, or half empty?
    Sounds like your camper has perform very well...
  • I really don't see how you can blame them on a 3 year old camper. The valve could have frozen and caused it to break the nex time it was used and that can not be blamed on the manufacturer. The light lens although I would say is a manufacturer problem. If you call them I'm sure they would be happy to send you one. The valve however I would just go to home depot and buy a shark bite valve and install it.
