Does anyone know if steel braided gas lines are ok to use? I need to run new lines from the black pipe, and plan on using pre made stuff from menards. Thankyou
You do not want to use steel braided out of the plumbing department used for water lines. They have rubber gas lines that you can use. I would use copper!
