shasta24ExplorerFeb 21, 2014Gas lineDoes anyone know if steel braided gas lines are ok to use? I need to run new lines from the black pipe, and plan on using pre made stuff from menards. Thankyou
greendeExplorer IIFeb 21, 2014If the lines are rated for gas, you should be okay. Remember, the teflon tape used on the fittings should be rated for LP. Usually yellow in color.
Related Contentreplacement gas pilot line and thermocoupleHigh pressure gas lineWiper Fluid in Water linesClass A LP Gas LineGas Line To Stove
