Does anyone know if steel braided gas lines are ok to use? I need to run new lines from the black pipe, and plan on using pre made stuff from menards. Thankyou
Copper lines have been used for years in the RV industry. Make sure you use Soft Drawn copper, not hard drawn. Hard drawn copper will work harden much faster with vibration and will crack. If you install soft drawn copper properly it will outlast the RV by many times.
