shasta24
Feb 21, 2014Explorer
Gas line
Does anyone know if steel braided gas lines are ok to use? I need to run new lines from the black pipe, and plan on using pre made stuff from menards. Thankyou
GrandpaKip wrote:myredracer wrote:
If a person wants to install, say a BBQ quick connect fitting 10' or 20' away from where a capped tee is, is there any reason why you can't just use the appropriate LP rubber hose?
I agree with the copper but I think you'd want to protect it with some plastic wiring loom?
I don't think there are any ready made hoses that long and making the hoses is not usually a DIY. I also wouldn't want a long permanent run of rubber hose.
All of the exterior copper on mine is covered with plastic tubing.
