hmknightnc
Sep 16, 2014Explorer
If your proposed gas generator has a fuel pump then using an external marine gas tank with appropriate connections should work just fine. If no fuel pump on generator to draw fuel it's not going to work unless maybe you can position the tank above the generator.
44,071 PostsLatest Activity: Aug 30, 2026
