CampingN.C. wrote:
"Originally Posted by General Motors
LOCKING DIFFERENTIAL LUBRICANT (SERVICE INFORMATION) #91-4-109
SUBJECT: LOCKING DIFFERENTIAL (G80) LUBRICANT - (SERVICE INFORMATION)
VEHICLES AFFECTED: ALL LIGHT TRUCKS EQUIPPED WITH G80 REAR AXLE ALL YEARS
Some light duty trucks equipped with locking rear axles (G80) may exhibit rear axle chatter, especially when turning a corner from a stop.
This condition of alternate engagement and disengagement of clutches in differential assembly is usually caused by contaminated axle lubricant.
To correct this condition, drain and refill the rear axle with SAE 80W-90 GL5 (P/N 10950849).
The use of any additive in locking rear axles (G80) is not recommended. Rear axle additives are designed for use in limited slip differentials which are normally installed in cars. All light duty trucks equipped with RPO G80 make use of a locking differential and the use of additives will delay the engagement of the locking mechanism and may decrease axle life.
Exactly. This says you should not use an additive to
thier specified gear oil. If you read up on GM's part number for this (the gear oil that is), as well as the specs on the G80, they do actually use an additive so you don't have to. Takes out the guess work.
