brently0725's avatar
brently0725
Gluing on aluminium checker plate
Hey folks,
First post here and I'm looking for help. I have a 2007 Jayco 20ft travel trailer. Before I bought it somebody closed the door while the latch was in place and broke a hole in the bottom of the door.
I had a buddy cut me up some checker plate aluminum to cover the front and back door mainly to hide the hole and to make it match the checker plate on the front of the trailer.
My question is what glue or installation tips would you folks have for me to attach the thin aluminum to the what seems like plastic covered door.
There is foam inside the door I've found out from the 4" hole that is there.
Thanks in advance for any input!. Cheers!!
  • There are purpose built automotive adhesives on the market but I haven't used them. Vehicle mfgs use them to attach body panels and interior moldings.
    3M is where I go when needing a purpose built adhesive. Their products always stand out as a good choice. I have used their trim adhesive on vehicles for many years and they have always brought a good result.
  • I wouldn't use a washer on the front of the rivet where you will see it. Yes some sealant around the hole wouldn't hurt.
    Bill
  • Like an aluminum rivet with a large washer on them? Should I use a glue or any sort of sealant to go around that hole?
  • The checker plate is very thin (thinner than 3/16") and the front door piece is 12" x 24" and the rear bunk door piece is 12" x 27".
