egarant's avatar
egarant
Explorer III
Dec 15, 2014
Happi Jack 4560's stop....
When raising the camper off of some saw horses to put back on the truck, I am raising the camper about 1', the jacks work just fine.
When raising the truck from a much lower position, like when you would use it off the camper and I need to raise it over 2' is when I am having an issue.
The HJ's have a mechanism that stops them after one minute of continuous use (up or down) then you just push any button on the remote and away you go.
I get about 1 foot of lift out of the way, then the entire electrical system shuts down. No jacks, no lights, nothing. Then in less than a minute all is working again and I can raise the camper some more.
The jacks are on a 30 amp fuse, the larger silver looking type. I thought that might be tripping but that would not shut off the entire camper.
It would also be symptomatic that the batteries were low, but mine are brand new Lifeline's, fully charged. I didn't get the exact battery voltage while using the jacks this time out, but I will next time just the rule that completely out.
This is never an issue when lowering the camper, so it is probably connected to the increase amperage used when raising the camper.
Any thoughts other than the batteries being an issue?
