bigfootford
Apr 30, 2016Nomad III
Kawasakiklx wrote:
No load on jacks. I'm using a 12v test light. Ground clip to jack's ground positive point with bulb on bolt attached to camper. There is definitely 12v being sent through the frame. I can't find the wiring or jack controller. Pretty new to campers.
That is normal.. The frame is connected to the - of the battery.
Leave the test light on there and that same wire... One direction of the jack the light will light the other direction and the light will be off... You do not need to have the connection to the jack to test this.
One direction of the jacks and One wire will be + to the frame.... the other direction the other wire will be + to the frame...
