bigfootford
Apr 30, 2016Nomad III
Trying without quotes.. unable to insert a url to for Atwood... Will do that in the next post.
Kawasakiklx said "The side I see sparks is the side with the two switches. If I disconnected it, I would hAve no way to run the other side.
I took the whole assembly apart yesterday and found no wires shorting. I disconnected the jack without the switches and it still shorted."
I am trying to understand how you raise and lower the camper with your switches...
You do not have a wired remote I presume... And your switches are not like this described and shown on this pdf?
The control switches for the front 2 jacks are located in the front of the camper on one side, where the arching is occurring?
So if you tell either jack to go up or down the short occurs? Is this correct?
Jim
Jim
