Kawasakiklx wrote:
I need some pretty urgent help with my camper. I went to put down the front set of electric Atwood jacks on my camper this afternoon, and they worked intermittently. They didn't work at all at first, but then they started working, but were shorting on the bracket where they bolt to the camper.
Now, while putting a test light on the ground wire, when the jacks don't work, I have 12v at the camper frame. It is either working fine, sparking where bolts go into mount, or fully shorted to frame.
Please help!! What could cause this intermittent short?
When you say that there are sparks where the bolts mount jack to the frame that makes no sense to me... The bolts/brackets are tight so there should be no sparking. Are the bolts loose?
When you say you have 12vdc to the camper frame were are you placing the other lead of the test light? The camper frame will always be the negative of the battery!
So any 12vdc source will make the test light light... The frame is not the + of the battery!
If there was a full short to the frame it should blow a fuse or trip a thermal breaker if your camper has one installed on the + lead going to the jack controller.
Like Bootycall said, the only way for the motors to short would require an internal short of the motor...
The body of the motors are completely isolated from the metal outside casing. There should be no internal connection going to the case of the motor.
Each motor has it's own set of wires coming from the controller. When operating they will be either +/- or -/+ polarity to make the motor turn CCW or CW.... Those wires have not connection to the frame of the camper..... They come direct from the controller electronics.
If you are using a meter or test light, one lead on the frame of the jack and the other on one of the leads to the motor and make the motor run you will either see no voltage of 12 vcd/test light lit or not... Depends on the direction you are trying to make the motor turn.
Jim
