ib516's avatar
ib516
Explorer II
Mar 03, 2017
Ike Gauntlet 2017 3500s DRW 22,800# load
Pretty surprising results
Uphill towing 22,800#
1. Chevy Duramax 3.73 axle ratio (445hp/910tq) 10 min 16 sec
2. Ram Cummins 4.10 axle ratio (385hp/900tq) 10 min 28 sec
3. Ford Powerstroke 4.10 axle ratio (440hp/925tq) 10 min 31 sec
  • 4x4ord's avatar
    4x4ord
    Explorer III
    ib516 wrote:
    The hp/tq specs definitely don't directly correlate to the times on the uphill portion. Impressive none the less. That's a lot of weight to haul uphill.
    Mind you, it doesn't have the wind resistance a large 5er would.
    The aerodynamic drag on a load like that is greater than an RV even though the surface area is smaller.
  • rhagfo's avatar
    rhagfo
    Explorer III
    :h
    Well I like to see them all run, but, in 2011 and 2012 when Ram didn't have the ratings to match the Chevy and Ford, they didn't get to run the Ike. This year they just lowered the test to the lowest value.
    It would be interesting to see how the Chevy would do with 4.10's.
    It would be interesting to see an "RV" where the hook up a big heavy, Tall 5er and run the Ike.
  • The hp/tq specs definitely don't directly correlate to the times on the uphill portion. Impressive none the less. That's a lot of weight to haul uphill.
  • The fecal matter has hit the ventilator. Blue oval fan boys will be here directly to explain
