- ramincrExplorerAndre Smirnov
March 4, 2017 at 11:43 am
We did not detect any mechanical or software fault with the Super Duty. We did run the truck twice with similar results. We reported the best numbers - brulazExplorerA test on a different slope that puts the trannys in different gears could completely change the order results, especially as they are already extremely close. Although one of the worst, this is just one hill.
The downhill braking results are more interesting to me than the uphill. Although I would like to see a slower, windier descent with many 20mph hair-pin curves. - spoon059Explorer III
mtofell1 wrote:
3 GREAT truck all within a hair of each other + 1 specific test on 1 day = 5 Years of pointless internet forum bragging and boasting.
Anyone who concludes anything other than these are 3 great trucks on very equal footing needs to stop looking through the prism of their favorite brand.
THIS! - ramincrExplorerThey tested the Ford twice and gave it the best results
- Wild_CardExplorer
blofgren wrote:
ShinerBock wrote:
blofgren wrote:
Wouldn't an indication of this be noticeably less fuel economy than the other trucks? Also I would think if that new of a truck was in regen that soon there must have been something wrong with it.
No, defueling a diesel does not give you less fuel economy. It will give you less power from the engine. Well, technically you will use more fuel because it takes you longer to get up a hill versus having full power, but seeing that all of these trucks were about the same time, it wouldn't have been noticeable in this test.
Most modern diesels are programmed to defuel if certain parameters are over their limits like EGTs or boost pressure. Another form of defueling is torque management where you do not get full engine power in the first few gears because the ECM programs it to inject less fuel until you get into the higher gears.
Gotcha. The few (and very few) times my truck has gone into regen the only way I've known is that the fuel economy drops and after parking it I've noticed it has a very "hot" smell from the exhaust. I've noticed no difference in power, but it only regens when I'm not pulling so that is not surprising. It never regens when towing presumably because the exhaust is hot enough to burn off particulate naturally.
Don't know what you are driving or how many miles on it...but Most regen every 1k miles needed or not. - 4x4ordExplorer III
CumminsDriver wrote:
I haven't seen this mentioned yet, but since the Chevy and Ford are very close power wise, and the results reflect that, maybe the Ram was just a very good performing truck which really surprised everyone?
Rich
If all three trucks were putting out their claimed power the Chev would come in about 30 seconds ahead of the Ford but the Ram would have been 2 and a half minutes behind the Ford. The new Duramax is claimed to have 150 lbft of torque and 48 more HP than the previous Duramax, yet it seems to be very comparable to the outgoing model. So it seams to me that both the Ford and GM were not performing anywhere close to where they should have. - HuntindogExplorerRegening does not reduce power, only MPGS.
- HuntindogExplorer
patriotgrunt wrote:
That 30K spec is not a realistic number for Rvers.Lessmore wrote:
Chevies have always been known for outstanding power...all starting back in 1955 with the introduction of the legendary small block Chevy V8. Power and lots of it...has been a bow tie tradition in both gas and diesel engines over the years.
So no....not at all...nope.... I'm not surprised that Chevy came first and Ford was at the tail end.
Some say horse power is horsepower....but in my humble opinion horses are rated differently....there are Shetland horses (blue oval) and then there are Clydesdale's (bow tie). :B
All I can say...is it is a good thing that the Chevy was 'hobbled' with 3.73's to the Ford's 4.10's....or could you imagine what the Chevy times would of been.
Remind my again why these trucks are only pulling 22,800#s? :B
A 30K 5ver will have approx. 7500# pin weight.
None of the trucks are capable of that. - blofgrenExplorer
Gotcha. The few (and very few) times my truck has gone into regen the only way I've known is that the fuel economy drops and after parking it I've noticed it has a very "hot" smell from the exhaust. I've noticed no difference in power, but it only regens when I'm not pulling so that is not surprising. It never regens when towing presumably because the exhaust is hot enough to burn off particulate naturally. - blofgrenExplorer
Rich
Or perhaps received a non advertised power bump. Mr truck did say the exhaust brake did improve from last year.
Come on now, Fish. You know as well as we do that a power bump would certainly be advertised. Maybe that little inline 6 does actually pull pretty good..... ;)
44,066 PostsLatest Activity: Oct 04, 2013
