mfoster711 wrote:
dodge guy wrote:
Here is what I got out of that. If you don't do any research and you are not sure what your tongue weight is then buy the hitch that will work for everything! sounds like a customer service rep answer to me, "anything to buy our product!"
I think that is a misinterpretation of what he said. Also, you need to remember that his response is a response to my question. I did not ask if the 14k hitch will work for everything.
dodge guy wrote:
Or you can go by the educated answers and get the hitch that matches your loaded tongue weight.
I still don`t understand why everyone goes through all the trouble of looking at truck weights, trailer weights, GVWR and axle weights, and research on the vehicles your looking at, then throw all that knowledge out the window when looking for a hitch?!
Again get the hitch that matches your trailer loaded tongue weight!
I am curious, are you suggesting that there is only one size hitch from each company that is proper for a particular tongue weight? For example, if you have 985 tongue weight then the 1000 lb hitch is the only hitch that is proper and will work and that getting the 1200 lb hitch would cause a horrible ride and might cause a bent frame?
Ok back to your original question. Yes if you are on the high end of a 1200 lb hitch then going to a 1400lb hitch may be OK. But I would not do it because if it is 1200lbs then all you need is a 1200 lb hitch. If your getting into the 1250-1300lb range then yes go to the 1400 lb hitch! It's all in the research.
As far as one hitch from each manuf for a particular tongue weight.....yes each one has a system from 600 on up to 1800 or maybe even 2000lbs tongue weight. I know Reese makes (or they used to) make a hitch for PuPs. It was a single bar WD hitch for 400lb tongue weight. Now we know using a 1400lb hitch on a 1200 lb tongue weight trailer isn't going to break anything (at least it shouldn't) but it will not be sized appropriately and adverse handling could result because of it.
If your tongue weight is 1200 lbs get the 1200 lb hitch. My first trailer had between 750 and 800 lbs tongue weight, so I had 800lb bars. When I bought my current trailer the dealer swapped my 800lb bars with a set of 1200 lb bars, no charge, even though I was willing to pay for the new bars.
So in the end, it's always better and safer to match the loaded tongue weight to the WD hitch bars. It will handle and ride better, and be safer.
P.S. Notice how much more in depth our responses are to your question than the customer service rep at EQ (or any manuf. for that matter).
