d3500ram
Jan 10, 2022Explorer III
BigSwick wrote:
Hello all. I am fairly new to truck campers, about a year now. I have been leaving the camper- Cirrus 820- sit on the jacks when not in use. Sometimes for a month or two. Is a platform or stand needed to take the weight off of the jacks when not in use? And if you use them, how did you construct them? TIA and Happy New Year!
This is what I did when I had the TC:
I use 5 tiers of PT 6x6: There is 3/4PT attached to the bottom of the camper and 2 6x's - continuous in the long direction tiers, 3 each in the short direction. This is to fully support my camper when off the truck at home (I never take it off in the field.)
The lumber takes almost all of the weight as the jacks are there just to keep it all steady... just a crank or 2 on the jack the hit the ground. I feel this is very stable event though it it relatively tall. I do not need to go much higher when loading it on to the truck. I regularly get into the upper cab to access the upper cabs or make the bed and it is VERY stable.
One other thing to consider:
I would recommend checking with the camper manufacturer on their take whether or not the TC can be unsupported with water, waste tanks, etc.
