Fishy_Old_Man's avatar
May 05, 2016
Jay Flight 6 gallon water heater
Looked at 2016 Jay Flight with 6 gallon hot water heater. My first camper several years ago had a 6 gallon heater and we got by with it but did have concerns. Since then we've had doing but 10 gallon tanks.
Are the new 6 gallon heater better than the old heaters or should I keep looking?
Thanks for any help you can provide.
Fishy
  • While we get by, I don't believe the 6gal heaters work any better than they used too, especially if you are used to 10gal.
    I see a lot of 6cu ft refrigerators, which are too small.
  • Our gas or electric water heater is non adjustable and way too hot. I turn it on till it heats up and then turn it off till we use up the hot water.
    It is a 6 gallon unit and I have been told that for quick recovery you can used both the gas and electric. I have never tried that.
  • I have always had 6 gallon water heaters but I always modified them . Being a plumber it was easy. I changed the thermostats to heat the water to 140 degrees and installed a thermostatic mixing valve at the back of the water tank to mix in cold water set at 110 degrees which this set up gives me 10 gallons of hot water
  • When I think we're going to really use it I'll run both gas and electric. If it does run a little cool it doesn't take long to build back up.
  • The two of us get by fine. 20 minutes between showers is the only drawback.
  • 6 gallons works for me just fine but I don't take long showers or do three meals of dishwashing either. Without knowing how your system is being used, I'd guess answers are going to be all over the place.
