AISURFFISH
Jun 25, 2015Explorer
Lance 992 Propane Generator Run Time
I know I am going to regret posting this but here it goes???
Have any of you ran the on board propane generator with the AC through the night? What is the run time on a single 20 lb tank? I do have 2 on board just in case. I am looking at 11pm thru 6am ish so 7 hours per night for 3 nights. Once the camper get to the desired temp it should hold the cold quite well.
I am planning on an off the grid trip and will have to run the AC at night due to the temps and humidity. I am not going to sweat through the night, I have AC and I plan on using it.
Please hold off your noise complaint comments and other un-needed input. I will not be around others that the noise would effect.
The camper is a 2013 Lance 992 with 2 - 20lb tanks and the factory ac unit with electronic stat.
There will be a Walmart near so a tank swap is always an option if I get low on the first tank.
