- KittykathExplorer II
DutchmenSport wrote:
I'm not seasonal, but the seasonal campers I've encountered unhook and roll up their water hoses if they are going to be gone long, like Monday through Friday. Reason? Grounds keepers don't have to work around them to mow the grass, theft, and it just makes them feel better.
This is exactly what we do for the same reasons, and we'd unhook even if lawncare wasn't a concern. - fla-gypsyExplorerTurn it off at the faucet
- Old-BiscuitExplorer IIIAfter $6000 in repairs due to a line blowing off.......I'm a convert to turning it off.
Our mishap happened overnight while sleeping. Woke up to 2" swimming pool in kitchen/living room and enough water had flowed out under slide outs that our site and adjacent site were flooded.
So YES.....turn it off and disconnect the hose when leaving for sure!!! :B - dadmomhExplorerProbably just turning it off is plenty, but disconnecting is a for-sure. Once you've been at the CG for a while, you should have a feel for the area and the security. The one thing that disconnecting does is to highlight that no one is there. Most likely not a problem. If you just shut it off, be sure to remember to open the faucet furthest from the connection to let the pressure off and then close it back up.
- RoyBExplorer IIIIf it ever freezes where you are leaving your trailer you would definitely want the city water hose disconnected from your trailer when you are not around.
I'm not a seasonal camper either but I would probably disconnect everything and lock it up best I could. I would definitely pull the battery leads as well.
Roy ken - DutchmenSportExplorerI'm not seasonal, but the seasonal campers I've encountered unhook and roll up their water hoses if they are going to be gone long, like Monday through Friday. Reason? Grounds keepers don't have to work around them to mow the grass, theft, and it just makes them feel better.
- obgrahamExplorerJust the day: turn off at the spigot.
Overnight or longer: unattach everything, slides in, lock up and batten down. - notevenExplorer IIIWe turn off shore valve or on board water pump when leaving the unit unattended.
- Tim_WExplorerWe just shut off the water at the valve.
- jaycocreekExplorer III turn it off and disconnect if more than just the day. I've seen kids turn the water valve back on.I always have water in the rv tank, so it's know big deal or hurry when I get back.
