Ivylog
Feb 26, 2017Explorer III
The hitch is slightly in front of the rear axle... raising the front will INCREASE the hitch height slightly not lower it :S. You probably have some blocks between the springs and the rear axle because it's a 4X4 that can be removed. Cut 1/2" pipe spacers so you can reuse your U bolts.
