popcan's avatar
popcan
Life span of Arctic Fox or Nash trailers, and towing them
Hi all,
Just joined up, as I am about to buy our first TT! We are going to start used, and smallish, and see how we like it. I'm hoping to get some good advice and even simply your opinions on the following:
I have targeted an Arctic Fox and a Nash, both pre-owned 19b Models. the AF is year 2000, and the Nash is 2007. There are some minor (?) differences between them, ie things like a roof access ladder (do we need that?) and swing out hand railing on the AF, but the floor plan is identical. I do know that the AF is a little higher end, but this Nash is quite well equipped also.
What I'm wondering is; what is the life expectancy of a TT like these, if well maintained? I'm a little concerned about the age of these.
Second question;
I also wonder if I'm good to tow one of the above TT's with my 2008 Silverado 1500. It seems like there are so many half ton pickups towing big TT's, yet the on-line towing calculator I used seemed to suggest that these two trailers would be too much. Either there are many people overweight out there, or I am missing something. (I'm betting it's me!) I must be inputting something wrong, or interpreting the results incorrectly...
Specs:
The Nash has a dry weight of 3750lbs, GVW of 7000.
Hitch weight is about 350lbs.
The AF is slightly heavier with a dry weight of 4380lbs, but still a GVW of 7000. Hitch weight about 400.
My Silverado is an extended cab standard box. GVW of 7000lbs, GAWR front and rear are both 3950. From my manual, the max combined GVW is 13000, max listed trailer weight is 7500, and my truck has the 5.3l V8, 3:73 gearing.
All this stuff is making my head spin - I have a lot to learn.... HELP! lol
