Keith_Haw
Dec 10, 2013Explorer
Load leveling
I know this has been beat to death but still having trouble deciding which is best for my truck. Really hated to start another thread on this but kind of need to figure this one out. I have a 1999...
I have a 1999 Ram 2500 and pull a Wave 26RLS with just over 800lb tongue weight, 7200lb unloaded/ 8600lb loaded. In the late 90's Dodge went with longer softer springs. While it does improve the unloaded ride it really sags when hooked to the trailer, and at the same time allows quite a bit of sway. We do use a WD hitch and dual friction sway bars.
I've read all the post on the different systems, air bags/helper springs/Tembram/RAS, but can't decide which would be the best for my use. I'm looking for something to help level the truck when hitched, and also help a little with the sway, without killing the ride. My truck didn't come with factory overload springs so not sure that isn't all I need. While it pulls just fine the way it is setup it sits so low in the rear I have to run an extended receiver bracket to keep the trailer level. That also interferes with the trail gate opening.
What do y'all think?
