moonlitsouls wrote:
Hope all is well ,
Setup:
2006 Ford F-350 Super Duty Lariat Crew Cab LB 4WD + 2019 Eagle Cap 811
the dry weight of my camper is 3350
the max payload of my truck is 4300
Unladen weight is 7000lb
MVWR of the truck is 11500
BUT the max payload of the tire is 3640 x 4 = 14560
thoughts? i want to make sure im not going to be pushing it too close
thanks
All of the TC weight will be on rear axle. So it is more like 3640x 2= 7280-rear axle weight of empty truck. This will be your available payload.
Is truck gas or diesel?
If gas you should be ok once you upgrade tires. You can get LR129 tires rated at 4080 (x2= 8160#).
