moonlitsouls's avatar
moonlitsouls
Max Payload Question
Hope all is well ,
Setup:
2006 Ford F-350 Super Duty Lariat Crew Cab LB 4WD + 2019 Eagle Cap 811
the dry weight of my camper is 3350
the max payload of my truck is 4300
Unladen weight is 7000lb
MVWR of the truck is 11500
BUT the max payload of the tire is 3640 x 4 = 14560
thoughts? i want to make sure im not going to be pushing it too close
thanks
  • Buzzcut1 wrote:
    If you are going by the sticker on the camper you are in for a shock. Those are notoriously low by 500- or more pounds. I would suggest going to a CAT Scale and weighing the rig then looking at the load rating of your tires
    So the dry weight is not correct? They should not be doing that
  • K Mac wrote:
    You're already over your max, but you don't know it. What does your set-up consist of ?
    interesting , i added some important notes to the main body of the initial post , let me know what you think about the tires. thanks a lot
  • You're already over your max, but you don't know it. What does your set-up consist of ?
  • If you are going by the sticker on the camper you are in for a shock. Those are notoriously low by 500- or more pounds. I would suggest going to a CAT Scale and weighing the rig then looking at the load rating of your tires
