kicker's avatar
kicker
Moving up from F 150 to F 350 6.7 diesel
I previously owned a 2010 F150 with 5.4 and tow package. I own 2009 Starcraft 2700BH with had a hitch weight of 850 and when loaded weighed around 6500#. I used a propride weight distribution set up. The truck pulled the camper fine but you knew you had a camper hooked up.
I traded that truck in at 125000 miles for a 2016 F350 6.7 diesel. Let me just say, that if you can afford the 10,000 upcharge for the diesel option do it. I have all the pwr you would ever want and then some. No more messing around with weight distribution etc. Can comfortly cruise at 65 all day long. I have put 2500 miles on while pulling the camper and have been avg 10mpg towing. Not sure this is good but the 150 avg like 8mpg. This truck is also
My daily driver and while not towing I get 19 to 20 Hwy and 13 city.
My set up is F350 6.7 diesel 3.55 gears and 18inch tires.
Only draw back is a 26 gallon fuel tank but there are tons of options to add an external tank. If you are the fence and can afford a super duty by all means buy it. You wont regret it.
Mike
