buechlerj's avatar
buechlerj
My China bomb story, could I have prevented it.
In June we purchased a 2007 Springdale 290CT. It has Power King Towmax ST tires that looked good with no unusual wear or any cracking. We had a 400 mile tow home from Boise in 85 degree weather and they worked well. They are dated 18th week of 2007 and I figured I would replace them at the end of the season. On June 27th we headed to Wenatchee which is about 180 miles, it was 85 degrees. 120 miles in I was in the left lane passing a semi and had to move into the rumble strip to avoid some tire debris in my lane. I did not hit them but as soon as I moved right my left rear tire was flat and shredding. Put the spare on, it still had a sticker on it and continued on. We met some friends to ride dirt bikes on July 1st and they brought me one of my old Goodyears for a spare. Tuesday the 2nd we headed home thru Wenatchee to the Grand Coulee dam on highway 2, It was 102 degrees.
Our next failure was a loud pop driving straight, the right front blew. Pulled into a field and put the spare with the old Goodyear. I always run my tires at 65 psi but I figured they might of over pressurized so I lowered all of the tires to 60 psi. 100 miles later the left rear went again and it was the spare which before Thursday had never been on the ground. I always drive 60 and on
the way home I weighed the trailer at a weigh station and it said 6860 on the axles. Would lower pressure of helped, lower speed or was it just bad tires to old?
